is there a way to configure the z axis to go higher when it it moving on to a new cut in the design? frequently I have a problem where unlevel wood has the router drag across it while travelling to new spot on the material
You can increase the safety height in Easel, by default it is 3.8mm.
Edit under Machine -> Advanced
