I prefer to use mm for most things, but the Easel waste board has inch lines already on there. When using Easel, it would be nice to use ‘mm’ in general, but still see the inch lines in the grid that are physically on the waste board.
I would suggest having the mm grid in blue as it is now (when using mm), and have the inch lines black or a light gray and not numbered/labeled.
Thanks!
