Just curious to see what the longest bit people have successfully used. I would love to cut some thick stock.
The deflection you get from a long bit makes using them very problematic. The larger the diameter of the bit the better, so use a 1/4 inch bit. But even then if you have more than two inches of stick out you are going to see a large loss in accuracy.
