Using the fonts
Having issues with the fonts.they ate not completing the letters.thankyou for any advice
This bugged me at first also, I always state that my bit is a 1/32 bit, even though I may be using a 1/16" or 1/8" bit. You must remember, by going one bit larger is no problem, but using a 1/8’ bit at a 1/32" setting will lose resolution. Try this.
As I have recently learned, measure the actual cutting part of your bit and enter that as the ‘custom size’. Using the default bit sizes won’t allow it to plunge into those tiny crevices required by the fonts.
