the program i am using cant export SVG files wath can i do
What program are you using and what type of files can it generate?
i am using onshape
it can export dxf and dwg files
You might try one of the many online converter sites or perhaps there’s a freeware utility somewhere.
Take a look at http://www.dxfconverter.org/
It will allow you to do a dxf to svg conversion online.
Download Inkscape (it’s free). Save your file as a DXF in Onshape, then open the DXF with Inkscape and save it as a SVG from there.
