Stopping problems
Writing to COM port (GetOverlappedResult): Unknown error code 31
Keep stopping the machine?
Just got a powered hub to see if that would fix it. NOPE!
Error code 31 points to your gcode file it seems.
“Error:31 There are unused axis words in the block and G80 motion mode cancel is active.”
Where are you seeing that error? What sender are you using?
But a powered usb port and has not stopped since. But to answer you it was on Console of easel
