I have created a design using Vetric Pro and have saved the design, toolpaths, summary and worksheet to a thumb drive. How do I go about getting this info to my X-Carve machine to begin the actual machining/carving process??
you will need to download the Easel post-processor for Vcarve pro. I believe it is available inside easel via a link. You’ll need to enable it within VCarve Pro, and then you will export the gcode for each of your toolpaths into an *.nc file, which you can import from inside Easel and carve.
Only if you want to use Easel as your sender.
If you want to use any of the other senders (UGCS, PicSender, etc.) you can download a post processor that will allow you to do so. You can find one here. Scroll down to the post processor section.
