Right side of y-axis 'slippy'
Something appears to be wrong with my x-carve calibration. I seem to have a very slippy right side motor on the y-axis of my 1000 x 1000 x-carve. I’m constantly needing to adjust it to bring it back to square with the other side.
For example, if I hand adjust the y-axis, the left side motor will move uniformly, predictably. The right side however moves like a rubber band - for every mm the left side moves, the right side might boing 20 to 40mm - not at all in unison with the movement occurring on the other side.
Any suggestions for a fix?
Check your wiring, sounds like the right motor isn’t connected properly, check at both sides of the gantry.
FYI - I’m not in the habit of hand moving the x/y axis (axes?) around the cutting footprint - I only do so to square up the axis as necessary.
I have 2 blocks that i place between the x-axis makerslide and the front riser plates when I power up the machine, this ensures I have square. Once powered you shouldn’t get out of square unless you have some other wiring or electrical problem with the controller or motor.
I don’t think it’s an electrical fault. If it were an electrical fault it would manifest randomly and I wouldn’t be able to cut anything neatly, predictably - especially complicated designs. Here’s my current project - a TV cabinet - 24mm deep panels - the x-carve cut 15 passes over the same path of each panel without an increment of tracking error.
I made the mistake of cutting the end panels without checking calibration, and they proved to run a little diamond shaped rather than square. All faults hidden via a liberal dashing of TimberMate.
Here’s the crux - If I recalibrate the y-axis before commencing a cut the accuracy is no problemo. But I don’t understand why I need to recalibrate the y-axis prior to every piece?
Edit - I just see your latest reply. Perhaps it is an issue caused by machine power up/down. Regardless, the right side of the y-axis seems much more slippy in movement than the left side… is that normal?
When you say slippy, do you mean only when not powered? Are your left and right belt tensions the same as each other?
The squareness is a known issue although I couldn’t quickly find any inventables instructions for the issue there have been many posts on the forum.
When I say slippy, that means any time I need to calibrate this axis by hand - push the gantry 1mm, slowly, softly, and the left side y-axis moves 1mm, but the right side axis will bounce ahead at least 20 or 30mm. It seems I need to calibrate this axis every time I use the machine. I figure it has something to do with this bouncy behaviour.
As you suggest earlier - I now use a spacer against the y-axis uprights to confirm calibration, brought about from this latest project hiccup.
Belt tensions appear to be the same as each other, although I have no means to confirm this beyond eye-balling.
My calibration test is to cut an engraved dot at each corner of a 700mm square, then measure diagonally for discrepancy.
I have never seen or read anything about the bouncy behaviour but a short video demonstration would be great.
Can do. Although i’m in Australia, and it’s too late/dark in my cave to shoot a clear video right now. I can make a short video tomorrow during the day time no problemo.
Can I upload videos directly here? Or do I need to link via Youtube?
YouTube works best.
Check your grbl parameter settings. Specifically make sure the $1 parameter is set to 255 ($1=255).
Use “machine inspector -> advanced”.
If you have the X-controller check to make sure that the torque reduction feature is turned off. (DIP switch 4 OFF, in the picture DIP switch 4 is in the ON position).
