Sorry , I was just asking a question .
Now how do you delete this from the forum ?
Yes. If you stop the cut and tell it it turned out ok, it will return to the original XY start position.
Change the bit and hit carve again. It will go over the already cut path though, so will not actually cut anything until it catches up to where you stopped it.
Or, if you catch it in time, you can just pause the cut, change the bit, and then resume.
You must re-zero your Z axis after changing the bit.
You can’t resume at the same spot in easel
After being converted, I’m a big believer in bump stops and G28.
Search the forums for how-tos.
I concur
Tell me more about using g28
Glad to see you back!
How the heck does G28 work?
G28, Fanuc’s zero return command, tends to be one of the more misunderstood Fanuc programming words. The zero return position is, of course, the machine’s reference position. A light (axis origin light) will come on for each axis that is sent to the zero return position. The zero return position is quite important: most programs begin from this location, most machines require that you (manually) send the machine to this position as part of powering up, and it’s a point of reference for fixture offset (machining centers) and geometry offset (turning centers) entries. Admittedly, G28 is among the most complicated programming words. Here we attempt to clear up the confusion.
G28 is a two-step command. In a way, it’s like a canned cycle. Two things will happen whenever a G28 is commanded. First the machine will move (at rapid) the axis or axes included in the G28 command to an intermediate position. Then the machine will rapid the axis or axes to the zero return position. At this point the related axis origin light/s will come on. By the way, if you have the single block switch on, you actually have to press the cycle start button twice to complete the G28 command - once for the intermediate position move, and a second time for the move to the zero return position.
The intermediate position is what confuses most people. In absolute mode, which most programmers prefer for general purpose programming, the intermediate position is specified relative to program zero. In incremental mode, it is specified relative to the tool’s current position. Maybe the best way to gain an understanding is to give a few examples.
For machining centers:
Consider this command.
G91 G28 Z0
In step one of G28, the tool will move to an intermediate position that is incrementally nothing (zero) from its current position in Z. In step two, it will go to the zero return position in Z (only). Note that X and Y will not move. For all intents and purposes, we’re telling the machine to move the tool straight to its zero return position in Z.
G91 G28 X0 Y0 Z0
In step one of G28, the tool will move to an intermediate position that is incrementally nothing (zero) from its current position in X, Y, and Z. In step two, it will go to the zero return position in X, Y, and Z (together). For all intents and purposes, we’re telling the machine to move the tool straight to its zero return position in X, Y, and Z.
G91 G28 X0 Y0 Z3.0
In step one of G28, the tool will move to an intermediate position that is incrementally nothing (zero) from its current position in X, Y. But in Z, it will move up three inches. Maybe the tool is in a pocket you need to clear before moving in X and Y. In step two, it will go to the zero return position in X, Y, and Z (together).
Watch out! Here’s what can happen in absolute mode. Consider this command.
G28 X0 Y0 Z0
Assuming the machine is currently in absolute mode (G90), step one of G28 tells the machine to move to the program zero point (probably a crash). Then, in step two, the machine will move to the zero return position (if it still can).
Some programmers don’t like to program (ever) in incremental mode. While I don’t consider using the incremental mode with G28 to be straying too far from absolute programming, there is a way to stay in the absolute mode when using G28. Consider these commands.
G90 G00 X1.0 Y1.0 (Rapid to hole position)
G01 Z-0.5 F5.0 (Drill hole)
G00 Z0.1 (Rapid out of hole)
G28 Z0.1 (First, stay right where you are in Z, then go to the zero return position in Z)
While this works, I don’t like it. I show it just for the sake of explanation. Essentially, we’re looking back in the program to the tools last absolute position so we can include it in the G28 command. Again, this does work, but someday you’ll probably change a tool’s last position. In this case you better also remember to change the related G28 command or you’ll be in for a big surprise!
For turning centers:
G28 W0
In step one of G28, the tool will move to an intermediate position that is incrementally nothing (zero) from its current position in Z. In step two, it will go to the zero return position in Z (only). Note that X will not move. For all intents and purposes, we’re telling the machine to move the tool straight to its zero return position in Z.
G28 U0 W0
In step one of G28, the tool will move to an intermediate position that is incrementally nothing (zero) from its current position in X and Z. In step two, it will go to the zero return position in X Z (together). For all intents and purposes, we’re telling the machine to move the tool straight to its zero return position in X and Z.
G28 U3.0 Z0
In step one of G28, the tool will move to an intermediate position that is incrementally nothing (zero) from its current position in Z. But in X, it will increase in diameter by three inches (1.5 inch move). Maybe the tool is below an obstruction (like a tailstock) you need to clear before moving in Z. In step two, it will go to the zero return position in X Z (together).
G28 X0 Z0
Note that now we’re commanding G28 in absolute mode. Step one of G28 tells the machine to move to the program zero point (probably a crash). Then, in step two, the machine will move to the zero return position (if it still can).
Some programmers don’t like to program (ever) in incremental mode. While I don’t consider using the incremental mode for G28 to be straying too far from absolute programming, there is a way to stay in the absolute mode when using G28. Consider these commands.
G00 X3.2 Z0.005 (Rapid to facing position)
G01 X-0.06 F0.012 (Face part)
G00 Z0.1 (Retract in Z)
X3.2 (Retract in X)
G28 X3.2 Z0.1 (First, stay right where you are in X and Z, then go to the zero return position in X and Z)
What about G53?
Most current model Fanuc and Fanuc-compatible controls allow G53 - movement relative to the zero return position. For machining centers that allow G53, the command
G53 X0 Y0 Z0
will send the machine (at rapid) straight to the zero return position in X, Y, and Z. Unfortunately, older controls do not allow G53. Since G28 works on all Fanuc and Fanuc-compatible controls, most programmers prefer to use the (complicated) G28 command so they can run their programs on all machines their company owns.
Maybe I’ll just flood them with info. I even said “Search the forums”.
