I was having problems with the y-axis chattering so I decided to go through the excercise of setting the current for the stepper motors. I managed to solve the problem with the y-axis (and a small problem with the z-axis) but have totally screwed up the x-axis. I start with the current at 0 and then slowly raise if and all I get is the x-axis sort of stuttering in place. There is no setting through the whole range of current that seems to work correctly.
Any insight is greatly appreciated.
Thank you,
Lee
