Hello,
I am from Germany and bought some plywood with coated beech approx 0.65mm thick on both sides.
On this material I carved some text and then I used Epoxy from a professional supplier and colored it in black .
After that (just to let you know that I am doing it the first time with Epoxy) I filled the carved text with the black Epoxy.
I am not sure if this is not the correct way , or the material is not the correct one to use, but it sucked the black colored epoxy or my only the color into the material.
The Epoxy is from a German supplier and also the color paste not powder is from the same supplier, so everything is from one supplier. Also the correct mixing is used 1:2
I have no idea what I made wrong. My assumption is that the material is to soft and can therefore suck the material into?
Any recommendation or thoughts for a beginner?
Thanks in advance
T.Pruefer
