Not going right
ok so i have a piece of wood on the waste board that measures 37 x25 the x carve is only going right to the 26 inch mark and then goes back its cutting the carving short has anybody had these problem thats in advance
I found this gem the other day;
Why do you say that the machine is 1000mm the machine should cut up to 31 inches wide ?
Ok I said 31 I was off buy 1.5 inches the machine is still shorting me
OK good, so it’s not just me :wink:
The post he is referring to is further down.
