Odd one, I upgraded my limit switches to hall effect sensors. Z triggers but doesn’t seem to allow the cycle to finish. It seems as if it does not move down far enough down to start the next part of the cycle.
Same wiring just added a 5v and groundTry experimenting with the $27 grbl parameter. Default value is 1.000 mm
You may need a larger pull off for the hall effect sensors.
Should have looked up the pull off. 3.25mm did it! Thanks!
