My shapeko tries to cut the design twice in two separate locations
I’m having issues with a simple design a square and a star off of easel I tried to cut it it cuts the square fine then goes over to the star tries to cut it and then moves over a quarter of an inch and try and starts to recut it again can anyone help?
Can you list the software you are using? If it is easel is there a possibility that the design has two squares and one is colorless.
I’m using the easel software but it not only happens with just the squares it happens with a design of my own
