My 3018 CNC software stops when it reaches the "writing configuaration" screen
When I try to set up my 3018 CNC using the Machine menu it stops at the screen stating “Writing Configuration”. Is there a fix for this? Any help will be appreciated
By the way I have tried the usual, rebooting of the machine, checking the power connection to the CNC, the correct COM port and the USB cable.
Are you trying to set it up as an X-carve? Through Easel?
There’s no reason to run Easel’s machine setup on anything but an X-carve.
