Hi everybody!
I need something very simple made out of 12mm MDF- a mortise and tenon template set. Not sure how to attach pics here, but I can email you a plan drawing.
It is one rectangle with a centreline cut into it, and a 4cm x 25cm rectangle cut out of it (the mortise). And another rectangle with a centre line cut into it, with two 5.5 cm rectangles cut out of it on one end to form a tenon.
These two pieces should then fit together (press fit- not too tight, but tight enough for you to be able to lift both pieces while only holding one of them), and the centre line should be consistently straight across the length of both of them.
I need it this week, and am paying $100AUD either cash or via PayPal.
Any takers? I’m in Prahran 3181.
Cheers! - J.
