Importing things to Easel easy. Is there a way to design it in easel and then save the design or Upload the design to your computer?
If you have access to the Gcode sending you can export the G-code and save it that way.
If you don’t have access there is a thread on the forum where you can request access.
Login to easel and choose machine at the top, then at the bottom of the drop down menu choose advanced, on the right of the advanced menu is a Generate G Code click that then choose export g-code. save to your computer as needed.
