Importing gcode from f-engrave
I friend sent me a gcode file, but he uses f-engrave. I was able to import it, but I was not able to work with it at all. How can I fix it. I would like to put it on a workspace so I can adjust my cut setting and send it back to be used on my cnc. Thanks
What software are you using? Editing gcode is typically done in a text editor, but you won’t be making changes to a design that way.
I am using easel, and the file was done in F engrave
You won’t be able to edit imported gcode. What were you going to change?
I barely know easel, so I just deleted the file.
