Hey gang,
What’s the trick to cutting out a shape on the line without making multiple paths?
Here you can see two blue lines.
Here’s what I get under cut settings,
On Path: cuts in two paths
Outline: cuts in two wider paths
Inside: creates a red line that won’t cut
Outside: creates red line that won’t cut
Fill: seems to be a possibility, but does not have tabs
All I want to do is cut through the outside of the California shape on one path instead of two paths. Thanks for any insight!
