took my first 3d clip art from vectric to easel. my carving was starting in the centre of vectric. now when i hav it at easel it is at the bottom corner to start carving. dont know how to centre it. please help
Its in the toolpath section under Material setup
As Easel default is for work zero is bottom left you should do that in your Vectric design and tool paths
If you had it centered in Vectric you need to have the ceter of your material as work zero.
