Question on Easel: Can you tell Easel to start a certain cut first. I would like to have Easel do my milling to a certain depth first before having it cut all the way through.
It Seems that the pieces you lay in last are cut first.
Get a scrap piece, and lay out one shape - square - circle, whatever,
then copy and paste it several times
When I did it, I numbered each one.
Then do a test carve and see which carved first.
then experiment with cutting and pasting different ones
I think you will find that your last piece moved or pasted it the first piece cut
Hope this helps
Martin
You can layout your individual shapes in separate working taps at the button and then cut these at your desired order. But in one work area it is not possible to tell what to cut first
FoxxFighter is correct.
However through cuts are always done last.
This is to prevent the project from breaking away during pockets or engraging.
Thank you for your response and helping a new x carve owner
