Export in easel
Why is there not a way to export a job in Easel
Hello, @KristianAng -
Actually, it is possible to export gcode from Easel. I suggest checking out this support article to learn how to do this. Let me know if you have any other questions!
Good morning (6.30Am local time) mstych (what a strange name bty)
It´s not the G Code I’m interested to export
it´s the work it self I´ve created in Easel
to open in another program to change
Kristian
Tjena Kristian.
In order to export information from Easel to different platform (another software) you need a “language” both sides can talk.
The only “output” Easel provide is gcode.
In order to change platform and change design (object) the workflow is as follows:
Easel object (your design) -> export gcode (machine instructions) // -> import gcode -> convert to object.
Anything to the right of the “//” needs to be done by the other program.
Since gcode is a path adjusted to whatever bit size you would use that same code will / may not import and be converted correctly according to your intent.
The workflow is awkward and I am not sure if it is a viable / usable method.
Unless I have misunderstood your question that is :wink:
