Hi all!
I have been using Easel with my non-Inventables CNC machine running GRBL and an Arduino. I cut one project using the Inlay app and it ran probably 99.9% perfect. I figure it would have been 100% if I slowed my speed down. I ran another different project with the identical settings and it resulted in erratic cuts with differing depths. It cut the initial shape properly but the depth went 3/16" deeper than the settings as well as it had a multi level bottom. I cut the inlay, two passes to a depth of 1/4" and the pocket, 2 passes to 3/16" and it cut twice as deep. I decided to cut a different project and everything was good!
When I create a project I generally use the project before as the template and copy the project so I have the settings set. The project was a basic inlay similar to Inventables video so not a difficult pattern. I went through all of Easel’s help suggestions but none of them addressed the issue I had (all of them really addressed the machine but not software or settings)!
Any help would be appreciated!
Thanks
Steve B…
