Is there a way to duplicate a small project to fit on the size of whats left on the board? So many will cut instead of having to recreate it many times?
So if I create something in Easel, I click that and it fills in a many as will fit on the dimensions of the board?
0k, why when you make your material 28" long, it doesn’t show on the work area (Left side)? I have the 1000mm xcarve.
I set it there, but the left side don’t show that, work looks like it’s off the material.
Yes
Do you know the width of the “red” bit? Where do I find that info so I can use the bits I bought in the super pack?
Likely 1/8", though you should really either measure the bit or cut a straight line and measure the cut to be exact.
