Is it possible to change milling
before the project is finished
I’ve done two different sizes of text
Kristian
http://easel.inventables.com/projects/bjalaNcobZ9Q3euwUPmyQA
Kristian
There is a feature being developed that allows for a rough pass and a detail pass. I believe this is what you want. Reply to this thread and Inventables will give you early access to the feature. You can then select two bits for your project.
Please send me the feature being developed that allows for a rough pass and a detail pass
Comment on the attached thread:
I’m not sure if it will work for you but when I want to do something that involves different bits on the same piece…
I know it isn’t the most efficient process but it works with my limited skill set at this point.
