Disclaimer:
Still making designs in Easel. Learning Fusion 360, just not there yet. So there’s that. Let’s speak no more of this.
Background:
I’ve made a design to be cut with a 30 degree bit. Did some practice cuts and it’s to my liking.
A majority of my work thus far has been using up-cut bits of this size and I’m good with that.
Question:
I’d like to also add elements to the design that would use a straight up-cut 2.6mm bits
When I use the “bit” and “detail bit” function to add the upcut bit, it states “Make V bit the Detail bit?” Sure, why not.
However, when I select the upcut bit size I want to use, and design element I create still looks like the v-bit patten in both the design and preview views.
So.
What basic element of education have I brazenly failed to commit to memory that would allow me to do both v-bit and upcut pattern elements in the same design, or
Can’t do it in Easel, or
I’ll just split the design into two elements (v-bit and non-v-but) and run it twice.
Thanks in advance for the corporate wisdom.
- Dan
