Belts are Drifting , tensions is off and Chatter.on Xcarve
Newbie reading all forum I hope to get one this Fall. Due to left side belt clip is lock down on the frame does not have screw in the top to hold from it move up . or you can add screw to set adjusted on back side then reset belt tensions on both front and back. Hope this will help out . First look at it.
Belts are move will cause some slipping ,is not a question just something to look at
Think he was commenting about the instructions on installing the belt. Recommending adding adjustment screws on both ends of each belt instead of just one end.
