I designed and just uploaded this bracket for Thingiverse which snaps onto my 46mm Festool vacuum hose to stop the hose from rubbing against the X-Carve drag chain. To install it I replaced the M5x20mm bolts that mount the Z motor with 25mm, installed the bracket on top of the original nuts and added a second set of Nylock nuts to secure the bracket. The hose snaps nicely into the bracket, but just in case something more is required I modeled in a passthrough that could be used for a Velcro strap.
great ideal !
added to my to do list
Very neat idea, I was thinking about different ways to support my vacuum hose so it doesn’t rub up against the machine itself too much and I thought I would have to settle for suspending the hose from the ceiling but I think I’m going to go with this approach instead! I also like the added bracket at the top of the router to keep the hose vertical.
Also, very nice shop by the way!
Right now I’ve got that heavy roller stand “feeding” the hose to the X-Carve which works (I had to put the clamps on the ends to keep the hose from sliding off), but it’s a little clunky. Someday when I get around to it I might attach a removable piece to the back of my X-Carve workbench with the rollers built in. I should probably make sure I don’t want to start using my big Delta dust collector instead of the Festool CT26 first.
